ScriptDispatch Object
The ScriptDispatch object represents the members defined in the configured browser script.
    [obj=] SiteKiosk.ScriptDispatch
    This object is available through the main object SiteKiosk. Use the ScriptDispatch object to use objects, properties and methods defined in the browser script file configured at "Browser Design -> Advanced -> Execute Script".
    In external script files, the alert method can only be used as follows: "SiteKiosk.WindowList.MainWindow.SiteKioskWindow.SiteKioskWebBrowser.
    WebBrowser.Document.parentWindow.alert('mymessage')".
    scriptfile.js (configured at "Browser Design -> Advanced -> Execute Script"):
    var mystring = "SiteKiosk";
    function change_mystring()
       mystring = "PROVISIO";
    The following example shows how to use members of the configured browser script file notated above.
    alert(SiteKiosk.ScriptDispatch.mystring);
    SiteKiosk.ScriptDispatch.change_mystring();
