Enabled Property
The Enabled property indicates if the second monitor is currently enabled.
[bool=] SiteKiosk.SecondMonitorBrowser.Enabled
The following example checks the availability of the SiteKiosk Player on the second monitor and navigates to a specified URL.
lb_2ndMonBrowserEnabled = false;
lb_2ndMonBrowserActive = false;
lb_2ndMonBrowserIsSKPlayer = false;
if(SiteKiosk.SecondMonitorBrowser.Enabled)
lb_2ndMonBrowserEnabled = true;
if(SiteKiosk.SecondMonitorBrowser.Active)
lb_2ndMonBrowserActive = true;
if(SiteKiosk.SecondMonitorBrowser.IsSKPlayer)
lb_2ndMonBrowserIsSKPlayer = true;
if(lb_2ndMonBrowserEnabled == true && lb_2ndMonBrowserActive == true
&& lb_2ndMonBrowserIsSKPlayer == true)
SiteKiosk.SecondMonitorBrowser.Navigate
("http://www.provisio.com/");
else
SiteKiosk.Logfile.Notification("2nd Monitor Enabled: " +
lb_2ndMonBrowserEnabled + ", Active: " +
lb_2ndMonBrowserActive + ", SKPlayer: " +
lb_2ndMonBrowserIsSKPlayer);
SiteKiosk v7.7 (and later versions).
