IsSKPlayer Property
The IsSKPlayer property indicates if the SiteKiosk Player is running on the second monitor.
    [bool=] SiteKiosk.SecondMonitorBrowser.IsSKPlayer
    Boolean value that retrieves the SiteKiosk Player status.
    The following example checks the availability of the SiteKiosk Player on the second monitor and navigates to a specified URL.
    lb_2ndMonBrowserEnabled = false;
    lb_2ndMonBrowserActive = false;
    lb_2ndMonBrowserIsSKPlayer = false;
    if(SiteKiosk.SecondMonitorBrowser.Enabled)
    	lb_2ndMonBrowserEnabled = true;
    if(SiteKiosk.SecondMonitorBrowser.Active)
    	lb_2ndMonBrowserActive = true;
    if(SiteKiosk.SecondMonitorBrowser.IsSKPlayer)
    	lb_2ndMonBrowserIsSKPlayer = true;
    if(lb_2ndMonBrowserEnabled == true && lb_2ndMonBrowserActive == true
    && lb_2ndMonBrowserIsSKPlayer == true)
    	SiteKiosk.SecondMonitorBrowser.Navigate
    	("http://www.provisio.com/");
    else
    	SiteKiosk.Logfile.Notification("2nd Monitor Enabled: " +
    	lb_2ndMonBrowserEnabled + ", Active: " +
    	lb_2ndMonBrowserActive + ", SKPlayer: " +
    	lb_2ndMonBrowserIsSKPlayer);
    SiteKiosk v7.7 (and later versions).
