LimitedUserMyDocuments Property
The LimitedUserMyDocuments property contains the documents directory of the restricted SiteKiosk user.
[str=] SiteKiosk.Security.LimitedUserMyDocuments
String that retrieves the path of the documents folder.
This string is empty if the restricted SiteKiosk user account has not been installed.
The following example shows the name of the documents folder in an alert window.
alert(SiteKiosk.Security.LimitedUserMyDocuments);
