LimitedUserProfileDir Property
The LimitedUserProfileDir property contains the path of the restricted user profile directory.
[str=] SiteKiosk.Security.LimitedUserProfileDir
String that retrieves the path of the directory.
This string is empty if the restricted SiteKiosk user account has not been installed.
The following example shows the path of the restricted user profile directory in an alert window.
alert(SiteKiosk.Security.LimitedUserProfileDir);
