RunningAsLimitedUser Property
The RunningAsLimitedUser property indicates if SiteKiosk has been started by the restricted SiteKiosk user.
[bool=] SiteKiosk.Security.RunningAsLimitedUser
Boolean value that retrieves the restricted user status.
The following example determines if SiteKiosk has been started by the restricted SiteKiosk user and shows it in an alert window.
alert(SiteKiosk.Security.RunningAsLimitedUser);
