SystemSecurityConfigured Property
The SystemSecurityConfigured property indicates whether the system security has been configured using the SiteKiosk security wizard.
    [bool=] SiteKiosk.Security.SystemSecurityConfigured
    Boolean value that retrieves the security configured status.
    The system security can be configured using the SiteKiosk security wizard.
    This property is true even if the SiteKiosk security wizard has been canceled after starting it.
    The following example determines whether the system security has been configured and shows it in an alert window.
    alert(SiteKiosk.Security.SystemSecurityConfigured);
