GetUsageTime Method
The GetUsageTime method returns the usage time of a computer.
[long=] SiteCafe.Server.Sessions.GetUsageTime(compIndex, sTime, eTime)
compIndex |
Long value that specifies the computer index. |
sTime |
Long value that specifies the start time. |
eTime |
Long value that specifies the end time. |
Returns a Long value that contains the usage time.
The start and/or end time will be ignored if they are 0.
Otherwise they are specified by the return value of the Date.getVarDate method divided by 1000.
The following example displays the usage time of the first computer.
alert(SiteCafe.Server.Sessions.GetUsageTime(1, 0, 0));
