OnCloseSession Event
Fires when a session is closed.
    SiteCafe.Server.Sessions.OnCloseSession = handler
    index Long value that contains the session index.
    The following example displays the index when a session is closed.
    SiteCafe.Server.Sessions.OnCloseSession = OnCloseSession;
    function OnCloseSession(index)
       alert("Session: " + index);
