OnSessionChanged Event
Fires when a session changed.
    SiteCafe.Server.Sessions.OnSessionChanged = handler
    index Long value that contains the session index.
    flags Long value that contains the change flags.
    Possible flags are:
    1 : inserted
    2 : updated
    3 : deleted
    The following example displays the index and flags when a session changed.
    SiteCafe.Server.Sessions.OnSessionChanged = OnSessionChanged;
    function OnSessionChanged(index, flags)
       alert("Session: " + index);
       alert("Flags: " + flags);
