ConfigureDatabase Method
The ConfigureDatabase method shows the database configuration dialog.
    SiteCafe.ConfigureDatabase()
    The database configuration dialog lets you choose the database that SiteCafe will use.
    The following example displays the database configuration dialog.
    SiteCafe.ConfigureDatabase();
