OnEndSession Event
Fires when a session ends.
SiteCafe.OnEndSession = handler
endsession |
Boolean value that indicates whether WM_ENDSESSION has been received. |
logoff |
Boolean value that indicates whether the user logged off. |
The following example displays alert windows when a session ends.
SiteCafe.OnEndSession = OnEndSession;
function OnEndSession(endsession, logoff)
alert("End of session: " + endsession);
alert("Logoff: " + logoff);
