OnTrayIcon Event
Fires when the tray icon is displayed.
SiteCafe.OnTrayIcon = handler
mouseX |
Long value that contains the horizontal mouse position. |
mouseY |
Long value that contains the vertical mouse position. |
event |
Long value that contains the window message. |
See Window Notifications (MSDN) fur further information about possible events.
The following example displays an alert window when the tray icon is displayed.
SiteCafe.OnTrayIcon = OnTrayIcon;
function OnTrayIcon(mouseX, mouseY, event)
alert("mouseX: " + mouseX);
alert("mouseY: " + mouseY);
alert("event: " + event);
