OnTrayPopup Event
Fires when the tray icon's shortcut menu is displayed.
    SiteCafe.OnTrayPopup = handler
    mouseX Long value that contains the horizontal mouse position.
    mouseY Long value that contains the vertical mouse position.
    The following example displays an alert window when the tray icon's shortcut menu is displayed.
    SiteCafe.OnTrayPopup = OnTrayPopup;
    function OnTrayPopup(mouseX, mouseY)
       alert("mouseX: " + mouseX);
       alert("mouseY: " + mouseY);
