EnableCodes Property
The EnableCodes property indicates whether code login is enabled.
    [bool=] SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
            EnableCodes
    Boolean value that retrieves the code login status.
    The following example determines whether code login is enabled and displays it.
    alert(SiteCafe.EnableCodes);
