EnableUsers Property
The EnableUsers property indicates whether username/password login is enabled.
[bool=] SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
EnableUsers
Boolean value that retrieves the username/password login status.
The following example determines whether username/password login is enabled and displays it.
alert(SiteCafe.EnableUsers);
