EncodeFile Method
The EncodeFile method encodes a file.
    [str=] SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
           EncodeFile(filename)
    filename String that specifies the filename.
    Returns a String that contains the Base64 encoded file.
    Base64 is a data encoding scheme whereby binary-encoded data is converted to printable ASCII characters.
    The following example encodes and displays a file.
    alert(SiteCafe.EncodeFile("c:/anyfile.cfg"));
