OnCustomMessage Event
Fires when a message has been received from the server.
SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
OnCustomMessage = handler
messageID |
Long value that specifies the message ID. |
message |
String that specifies the message. |
The following example displays the message when it has been received.
SiteCafe.OnCustomMessage = OnCustomMessage;
function OnCustomMessage(messageID, message)
alert("Message: " + message);
