OnDisconnect Event
Fires when the terminal has been disconnected from the server.
    SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
    OnDisconnect = handler
    The following example displays an alert window when the terminal has been disconnected from the server.
    SiteCafe.OnDisconnect = OnDisconnect;
    function OnDisconnect()
       alert("Disconnected from the server");
