OnExecuteJavascript Event
Fires when the server caused the terminal to execute a Javascript.
    SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
    OnExecuteJavascript = handler
    filename String that contains the filename.
    sendRetVal Boolean value that indicates whether the script should send a return value to the server.
    scriptID Long value that contains the script ID.
    The following example displays the filename when the server caused the terminal to execute a Javascript.
    SiteCafe.OnExecuteJavascript = OnExecuteJavascript;
    function OnExecuteJavascript(filename, sendRetVal, scriptID)
       alert("File: " + filename);
