OnLogonFailed Event
Fires when an error occured during logon.
SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
OnLogonFailed = handler
errorCode |
Long value that contains the error code. |
The following example displays the error code when a logon failed.
SiteCafe.OnLogonFailed = OnLogonFailed;
function OnLogonFailed(errorCode)
alert("Error : " + errorCode);
