OnPropertyReceived Event
Fires when a requested property has been received.
    SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
    OnPropertyReceived = handler
    userIndex Long value that contains the user index.
    status Long value that contains the status.
    name String that contains the name of the property.
    value String or Long value that contains the value.
    The following example requests and displays the user property 'anyProperty' of the first user.
    SiteCafe.OnPropertyReceived = OnPropertyReceived;
    function OnPropertyReceived(userIndex, status, name, value)
       alert("Value: " + value);
    SiteCafe.GetProperty(1, "anyProperty");
