SetProperty Method
The SetProperty method sets a user property.
    SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
    SetProperty(userIndex, name, value)
    userIndex Long value that specifies the user index.
    name String that specifies the name of the property.
    value String that specifies the value.
    Note that the value must be sent to the server as a string, even if it is a numeric value.
    The following example sets the user property 'anyProperty' of the first user.
    SiteCafe.SetProperty(1, "anyProperty", "value");
