ValidDuration Property
The ValidDuration property contains the number of seconds the account will be valid after the activation (first login).
[long=] SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
ValidDuration
Long value that retrieves the duration.
This property is constant.
Durations are a number of seconds.
The following example displays the number of seconds the account will be valid after the activation.
alert(SiteCafe.ValidDuration);
