CanCaptureAudio Property
The CanCaptureAudio property indicates if the used device can capture audio.
    [bool=] document.all["id_name"].CanCaptureAudio
    Boolean value. True if audio can be captured, false if not.
    The following example shows the CanCaptureAudio property in an alert window.
    <object id="webcam" border="0" width="250" height="200"
    classid="clsid:54632F4A-055A-44C1-B1E6-EDB62AC2AC3E">
    </object>
    <script language="javascript">
    alert(webcam.CanCaptureAudio);
    </script>
