CanCaptureVideo Property
The CanCaptureVideo property indicates if the used device can capture video.
    [bool=] document.all["id_name"].CanCaptureVideo
    Boolean value. True if video can be captured, false if not.
    The following example shows the CanCaptureVideo property in an alert window.
    <object id="webcam" border="0" width="250" height="200"
    classid="clsid:54632F4A-055A-44C1-B1E6-EDB62AC2AC3E">
    </object>
    <script language="javascript">
    alert(webcam.CanCaptureVideo);
    </script>
