CaptureAudio Property
The CaptureAudio property indicates if audio will be captured next time.
document.all["id_name"].CaptureAudio [=boolean]
Boolean value. True if audio is to be captured, false if not.
The following example shows the CaptureAudio property in an alert window.
<object id="webcam" border="0" width="250" height="200"
classid="clsid:54632F4A-055A-44C1-B1E6-EDB62AC2AC3E">
</object>
<script language="javascript">
alert(webcam.CaptureAudio);
</script>
