IsSiteCamEnabled Property
The IsSiteCamEnabled property indicates if the Webcam plugin is enabled.
[bool=] document.all["id_name"].IsSiteCamEnabled
Boolean value. True if the Webcam plugin is enabled, false if not.
The following example shows the IsSiteCamEnabled property in an alert window.
<object id="webcam" border="0" width="250" height="200"
classid="clsid:54632F4A-055A-44C1-B1E6-EDB62AC2AC3E">
</object>
<script language="javascript">
alert(webcam.IsSiteCamEnabled);
</script>
