OnProgressChange Event
Fires when the progress of an action changes.
    function id_name::OnProgressChange(progress, progressmax)
    progress DWORD value that contains the current progress.
    progressmax DWORD value that contains the maximum progress.
    Depending on which action is currently active the parameters contain the current progress and maximum progress of capturing or compression.
    align="center">
    <tr><td bgcolor="f8f8f8">
    </td></tr>
    <pre>
    </object>
    <br>
    <br>
       switch (webcam.Status)
       camlif = filename;
       switch (errorcode)
    function delfiles()
       webcam.DeleteCreatedFiles();
       if (webcam.IsSiteCamEnabled)
          switch (camactionid)
             case 5 : webcam.Stop();break;
             case 7 : delfiles();break;
    else
    </pre>
    </td></tr>
    </table>
    <div align="center">
    <a href="javascript:camaction(1)">Preview</a>&nbsp;
    <a href="javascript:camaction(2)">Capture</a>&nbsp;
    <a href="javascript:camaction(4)">Compress</a>&nbsp;
    <a href="javascript:camaction(6)">Play</a>&nbsp;
    <a href="javascript:camaction(3)">Snapshot</a>&nbsp;
    <a href="javascript:camaction(5)">Stop</a>&nbsp;
