Progress Property
The Progress property contains the progress of the current action.
[long=] document.all["id_name"].Progress
Long value that retrieves the current progress.
Depending on which action is currently active this property contains the progress of capturing or compression.
If capturing is active the value represents the captured seconds, if compression is active the value represents the number of samples.
align="center">
<tr><td bgcolor="f8f8f8">
</td></tr>
<pre>
</object>
<br>
<br>
switch (webcam.Status)
mypr = webcam.Progress;
myprmax = webcam.ProgressMax;
id_camprogress.innerHTML = mypr + " / " + myprmax;
camlif = filename;
switch (errorcode)
function delfiles()
webcam.DeleteCreatedFiles();
if (webcam.IsSiteCamEnabled)
switch (camactionid)
case 5 : webcam.Stop();break;
case 7 : delfiles();break;
else
</pre>
</td></tr>
</table>
<div align="center">
