ProgressMax Property
The ProgressMax property contains the maximum progress of the current action.
    [long=] document.all["id_name"].ProgressMax
    Long value that retrieves the maximum progress.
    Depending on which action is currently active this property contains the maximum progress of capturing or compression.
    If capturing is active the value represents the seconds, if compression is active the value represents the number of samples.
    align="center">
    <tr><td bgcolor="f8f8f8">
    </td></tr>
    <pre>
    </object>
    <br>
    <br>
       switch (webcam.Status)
       mypr = webcam.Progress;
       myprmax = webcam.ProgressMax;
       id_camprogress.innerHTML = mypr + " / " + myprmax;
       camlif = filename;
       switch (errorcode)
    function delfiles()
       webcam.DeleteCreatedFiles();
       if (webcam.IsSiteCamEnabled)
          switch (camactionid)
             case 5 : webcam.Stop();break;
             case 7 : delfiles();break;
    else
    </pre>
    </td></tr>
    </table>
    <div align="center">
    <a href="javascript:camaction(1)">Preview</a>&nbsp;
    <a href="javascript:camaction(2)">Capture</a>&nbsp;
    <a href="javascript:camaction(4)">Compress</a>&nbsp;
    <a href="javascript:camaction(6)">Play</a>&nbsp;
    <a href="javascript:camaction(3)">Snapshot</a>&nbsp;
    <a href="javascript:camaction(5)">Stop</a>&nbsp;
