Snapshot Method
The Snapshot method takes a single picture and saves it.
document.all["id_name"].Snapshot()
This method can only be called when the capture or preview mode is active.
The image will be saved as a .jpg file.
align="center">
<tr><td bgcolor="f8f8f8">
</td></tr>
<pre>
</object>
<br>
<br>
switch (webcam.Status)
camlif = filename;
switch (errorcode)
function delfiles()
webcam.DeleteCreatedFiles();
if (webcam.IsSiteCamEnabled)
switch (camactionid)
case 5 : webcam.Stop();break;
case 7 : delfiles();break;
else
</pre>
</td></tr>
</table>
<div align="center">
