Status Property
The Status property contains the status of the current action.
[long=] document.all["id_name"].Status
Long value that retrieves the current status.
The status is a value between 0 and 5:
0 : stopped
1 : initializing
2 : preview
3 : capture
4 : playback
5 : compress
align="center">
<tr><td bgcolor="f8f8f8">
</td></tr>
<pre>
</object>
<br>
<br>
switch (webcam.Status)
camlif = filename;
switch (errorcode)
function delfiles()
webcam.DeleteCreatedFiles();
if (webcam.IsSiteCamEnabled)
switch (camactionid)
case 5 : webcam.Stop();break;
case 7 : delfiles();break;
else
</pre>
</td></tr>
</table>
<div align="center">
