Stop Method
The Stop method stops the current action (capture, play, preview).
    document.all["id_name"].Stop()
    align="center">
    <tr><td bgcolor="f8f8f8">
    </td></tr>
    <pre>
    </object>
    <br>
    <br>
       switch (webcam.Status)
       camlif = filename;
       switch (errorcode)
    function delfiles()
       webcam.DeleteCreatedFiles();
       if (webcam.IsSiteCamEnabled)
          switch (camactionid)
             case 5 : webcam.Stop();break;
             case 7 : delfiles();break;
    else
    </pre>
    </td></tr>
    </table>
    <div align="center">
    <a href="javascript:camaction(1)">Preview</a>&nbsp;
    <a href="javascript:camaction(2)">Capture</a>&nbsp;
    <a href="javascript:camaction(4)">Compress</a>&nbsp;
    <a href="javascript:camaction(6)">Play</a>&nbsp;
    <a href="javascript:camaction(3)">Snapshot</a>&nbsp;
    <a href="javascript:camaction(5)">Stop</a>&nbsp;
