AccessStatus Property
The AccessStatus property indicates whether an access control device allows access.
[bool=] SiteKiosk.Plugins("SiteCash").AccessStatus
Boolean value that retrieves the access status.
For example, the time limiter or SiteCafe in time mode is an access control device.
This property is false if a payment device like a coin validator is used.
The following example shows the access status in an alert window.
alert(SiteKiosk.Plugins("SiteCash").AccessStatus);
