ApplicationPrice Property
The ApplicationPrice property contains the price per hour for using applications.
[double=] SiteKiosk.Plugins("SiteCash").ApplicationPrice
Double value that retrieves the price.
The following example determines whether using applications is charged and shows the price in an alert window.
appPay = SiteKiosk.Plugins("SiteCash").PayApplications;
appPrice = SiteKiosk.Plugins("SiteCash").ApplicationPrice;
if (appPay) alert("Price per hour for applications: " + appPrice);
else alert("Using applications is for free");
