CountDown Property
The CountDown property specifies if the surfing-time countdown is active or halted.
    SiteKiosk.Plugins("SiteCash").CountDown [=bool]
    Boolean value that specifies or retrieves if the
    countdown is active.
    If credit is available and the countdown is halted, surfing is still possible.
    The following example shows the countdown status in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").CountDown);
