CreditStatus Property
The CreditStatus property indicates if there is credit available.
    [bool=] SiteKiosk.Plugins("SiteCash").CreditStatus
    Boolean value that retrieves if credit is available.
    The following example determines if credit is available and shows the amount in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").CreditStatus);
