DiscardMoneyOnShutdown Property
The DiscardMoneyOnShutdown property indicates whether credit is discarded after terminating SiteKiosk.
SiteKiosk.Plugins("SiteCash").DiscardMoneyOnShutdown [=bool]
Boolean value that specifies or retrieves the discard status.
If this property is false, the current balance will be saved when SiteKiosk is terminated and restored the next time SiteKiosk is started.
The following example determines if credit will be discarded after terminating SiteKiosk and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCash").DiscardMoneyOnShutdown);
