Enabled Property
The Enabled property indicates if the Payment Module of SiteKiosk has been enabled.
[bool=] SiteKiosk.Plugins("SiteCash").Enabled
Boolean value that indicates if the Payment Module is active.
The following example determines if the Payment Module has been enabled and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCash").Enabled);
