Inpayment Method
The Inpayment method deposits an amount of a device.
SiteKiosk.Plugins("SiteCash").Inpayment(devname, amount)
devname |
String that contains the name of the device. |
amount |
Currency value that specifies the amount to deposit. |
This method must be called when the OnInpayment event fires.
The following example deposits the amount when a device received credit.
SiteKiosk.Plugins("SiteCash").OnInpayment = OnInpayment;
function OnInpayment(obj, amount)
SiteKiosk.Plugins("SiteCash").Inpayment(obj.ShortName, amount);
alert("Deposit: " + amount);
