Name Property
The Name property contains the name of this plugin.
    [str=] SiteKiosk.Plugins("SiteCash").Name
    The SiteKiosk Object Model name of the Payment Module plugin is "SiteCash".
    The following example shows the name of this plugin in an alert window.
    alert(SiteKiosk.Plugins.Item(2).Name);
