OnAccessStatusChanged Event
Fires when the access status changed.
SiteKiosk.Plugins("SiteCash").OnAccessStatusChanged = handler
The access status can be changed by connected Access Control Devices.
The following example shows an alert window when the access status changed.
SiteKiosk.Plugins("SiteCash").OnAccessStatusChanged = OASChanged;
function OASChanged()
alert("Access status changed");
