OnInpaymentFailed Event
Fires when an inpayment failed.
SiteKiosk.Plugins("SiteCash").OnInpaymentFailed = handler
An inpayment can be done using the DebitTrial method.
SiteCash devices that fire this event are ACOS Smartcards and the HW200 interface.
The following example shows the name of the device when an inpayment failed.
SiteKiosk.Plugins("SiteCash").OnInpaymentFailed = OnInpaymentFailed;
function OnInpaymentFailed(obj)
alert(obj.Name);
