OnRunningOutOfCredit Event
Fires when credit is running out.
SiteKiosk.Plugins("SiteCash").OnRunningOutOfCredit = handler
The following example shows an alert window when credit is running out.
SiteKiosk.Plugins("SiteCash").OnRunningOutOfCredit = OROOCredit;
function OROOCredit()
alert("You are running out of credit");
