PayApplications Property
The PayApplications property indicates whether using applications is charged.
[bool=] SiteKiosk.Plugins("SiteCash").PayApplications
Boolean value that indicates whether applications are charged.
The price will be charged per hour.
The following example determines whether using applications is charged and shows the price in an alert window.
appPay = SiteKiosk.Plugins("SiteCash").PayApplications;
appPrice = SiteKiosk.Plugins("SiteCash").ApplicationPrice;
if (appPay) alert("Price per hour for applications: " + appPrice);
else alert("Using applications is for free");
