PullMode Property
The PullMode property indicates if credit is currently being subtracted using the pull mode.
[bool=] SiteKiosk.Plugins("SiteCash").PullMode
Boolean value that retrieves if the pull mode is active.
The following example shows if the pull mode is active.
alert(SiteKiosk.Plugins("SiteCash").PullMode);
