TimePercentage Property
The TimePercentage property contains the remaining time in percent.
    [flt=] SiteKiosk.Plugins("SiteCash").TimePercentage
    Float value that retrieves the remaining time in percent.
    The following example shows the remaining time in percent in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").TimePercentage);
