AddPattern Method
The AddPattern method adds an URL pattern to the
Patterns collection.
SiteCashZone.AddPattern(str)
str |
String that contains the new pattern. |
When using SiteKiosk 6.5 and above and you want to add a local file, use file:/// and not file:// (e.g. file:///c:/program files/sitekiosk/html/startpage/start.htm).
The following example adds an URL pattern to the Patterns collection of the first existing zone.
SiteKiosk.Plugins("SiteCash").Zones.Item(1).AddPattern("newPattern");
