CheckFrames Property
The CheckFrames property indicates whether to check frames for this zone.
SiteCashZone.CheckFrames [=bool]
Boolean value that specifies or retrieves the check frames status.
The following example determines whether to check frames for the first existing zone and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCash").Zones.Item(1).CheckFrames);
